It is currently Thu Aug 21, 2025 12:24 pm
 Post subject: Uke-sized guitar
PostPosted: Sat Dec 07, 2013 2:23 pm
First name: Ringo
Here's a fun little guitar I recently finished and wanted to share. I built a concert uke a while back and love it, but as a guitarist I usually find myself wanting another string or two when I play it. 'Well, why not make a 5 string uke or a tiny guitar then?' I asked myself. I twisted my own arm a bit and soon was convinced to give it a try. This is the result: a little 16" scale Euro spruce/cocobolo... ukitar? guitarele? I don't know what to call it but it's somewhere between a concert and tenor uke in size and the nut and bridge are set up for either 5 uke-spaced or 6 guitar-spaced strings depending on the day.
 Post subject: Re: Uke-sized guitar
PostPosted: Sat Dec 07, 2013 2:30 pm
First name: Ringo
Specs:
-Bearclaw Carpathian spruce top
-Cocobolo back/sides/headplate
-Spanish Cedar neck (flatsawn!)
-Pau ferro and Spanish cedar laminated fretboard
-cherry bindings
-semi-gloss sprayed shellac finish
More pics:
The neck and stacked heel are flatsawn giving it a unique look:
The fretboard was made from half pau ferro and half cedro... this was to save weight to try to keep it from being too top heavy:
PostPosted: Sat Dec 07, 2013 2:38 pm
First name: Ringo
Some unique features...
Bracing:
The laminated fretboard gived the headstock join a unique look:
The finish is shellac sprayed until it has the right sheen. Open pores are not filled. I absolutely love these finishes... it is silky smooth to the touch and you can really see and feel the texture of the wood. I find myself disliking 'dipped in plastic' finishes more and more every day, though I know I am in the small minority
PostPosted: Sat Dec 07, 2013 2:40 pm
First name: Ringo
The bridge and nut were made to accept either 6 guitar-spaced strings or else 5 uke-spaced strings. I have not tried the 5 string uke setup yet; I will finish the uke nut slots then. It was lucky that the spacings worked out pretty well with very little compromise.
PostPosted: Sat Dec 07, 2013 3:07 pm
First name: Ringo
Oh, and here's what it sounds like:
These users thanked the author James Ringelspaugh for the post (total 2): TimAllen (Sun Dec 08, 2013 2:26 am) • jack (Sat Dec 07, 2013 4:22 pm)
PostPosted: Sat Dec 07, 2013 5:08 pm
nice sounding little guitar
PostPosted: Sat Dec 07, 2013 7:35 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
That's an awesome little Guitulele you've got there James. How fun!
How did you attach the neck? (Butt, M/T, Dovetail?)
PostPosted: Sat Dec 07, 2013 7:37 pm
First name: Tony
Last Name: C
City: Brooklyn
First, that coco is killer. Awesome job, sounds nice, looks amazing.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Dec 07, 2013 8:14 pm
First name: D
Last Name: S
Love the finish, the beautiful sound, and your amazing playing.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Dec 07, 2013 8:17 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I say that's outrageously cool and pretty! Now...personally, I would like to see those open pores in the wood filled before finishing, but that's just my personal preference. You mustn't take that as a criticism. It's not my little guitar. It's yours and it's a beauty. I think it's a very cool concept for an instrument and I think it is very well executed. Well done!
Patrick
PostPosted: Sat Dec 07, 2013 8:28 pm
WOW! That's amazing! :D I'm building a small guitar at the moment - baritone uke sized - May I ask how you went about compensating it?
Plan on my 1/2 size classical thread: http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=41311&p=555716#p555716
PostPosted: Sun Dec 08, 2013 11:27 am
First name: Ringo
Hi Beth, it's a simple butt joint with a single bolt + threaded insert. I calculated the string tension at 40 lbs total... with such a low tension pretty much any joint would do.
PostPosted: Sun Dec 08, 2013 11:35 am
First name: Ringo
Nylon strings aren't nearly as stiff as steel strings, so they generally don't need anywhere near the same saddle compensation. Even with pretty high action, I set the center of the saddle back only about one mm from the scale length and it seems to intonate just fine. If I were super nit picky I would compensate each string individually - and there's plenty of saddle to do it - but I am happy with it right out of the gate. Good luck with your build... I hope it's as fun to play as this one!
Edit: well I just measured with a nice tuner and it is a few cents sharp at the 12th fret. I guess the string size relative to the scale length makes it need more compensation than I had assumed, and the exact amount must depend on the strings. If I could back and do it again I might move the bridge back 2 more mm or I might try using much smaller gauge strings. I am using a set of D'Addario requinto strings btw.
These users thanked the author James Ringelspaugh for the post: Nick Royle (Sun Dec 08, 2013 1:17 pm)
PostPosted: Sun Dec 08, 2013 5:04 pm
City: winnipeg
State: manitoba
Country: canada
For what it is worth, I use the fret-calculator on the Stumac site for saddle location on weird scale lengths.
Bob :ugeek:
PostPosted: Fri Dec 13, 2013 2:43 am
Hi James, I thought of another question: What thickness did you take the top down to?
Cheers!
Nick
PostPosted: Fri Dec 13, 2013 11:47 am
First name: David
Last Name: LaPlante
Lovely!
I've made a few of these based both on the Martin Concert uke size and the Martin 1/4 size guitar.
These have been strung with steel, Nashville style, and are very effective in an ensemble.
PostPosted: Fri Dec 13, 2013 2:39 pm
First name: Shane
Last Name: Woonton
City: Wellington
Country: New Zealand
Beautiful James! Looks like the perfect little travel companion.
PostPosted: Sat Dec 14, 2013 8:31 am
First name: Jim
Last Name: Kirby
Very cool indeed! The look is great, but ...
... at least the rosette, which looks out of place against the rest of the top, which of course doesn't need the same filling. Again, overall, very nice.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Dec 14, 2013 9:57 am
First name: Ringo
Cheers!
Nick
Quite thin... I thinned not to a predetermined number, but by feel. It ended up at .075" off the thickness sander @ 80 grit, and I probably took another .010 off with final sanding and surface prep. I figured it would take a max 50 lbs of string tension so I went a little thinner than I normally would. I'd give you an exact final number, but the soundhole is too small for my caliper to fit!
Users browsing this forum: bobgramann and 19 guests
